Posted September 23, 20204 yr Notes: 1- youtube-dl.exe included to run video URLs 2- Disabled check for updates 3- Enabled Dark Theme 4- Enabled playback ability in the preview pane of Explorer 5- Command line switches: Auto install with Progress Only "/SILENT" Or Completely Silent "/VERYSILENT" 6- Enjoy! K-Lite Codec Pack Full 18.8.0 Silent Install Silent installation Silent installation Quote https://www.mediafire.com/file/q3vhcffu9nzs95n/K-Lite+Codec+Pack+Full+18.8.0+Silent+Install.7z/file https://mir.cr/BYCIGAI6 Edited February 10Feb 10 by 大†Shinegumi†大
November 3, 20204 yr Author Changelog 15.8.0 to 15.8.5 ~ 2020-11-02 Updated MPC-HC to version 1.9.8.19 Updated LAV Filters to version 0.74.1-77-g06f75 Fixed MPC-HC freeze/crash with subtitles on certain old systems since 15.7.5
November 4, 20204 yr Author Version 15.8.7 Mega ~ 58.8 MB ~ November 3rd 2020 Changelog: Updated MPC-HC to version 1.9.8.21 Updated LAV Filters to version 0.74.1-77-g06f75 Fixed MPC-HC freeze/crash with subtitles on certain old systems since 15.7.5
December 30, 20204 yr Author Changelog 15.9.0 to 15.9.5 ~ 2020-12-28 Updated MPC-HC to version 1.9.8.109 Updated LAV Filters to version 0.74.1-92-g88da5 Updated MPC Video Renderer to version 0.5.1.1584 Added option to MPC-HC to show a thumbnail preview on the seekbar You can enable it during installation, or through: MPC-HC options > Tweaks > Show Preview on Seekbar Edited December 30, 20204 yr by 大†Shinegumi†大
February 11, 20214 yr Author Version 16.0.0 Mega ~ 58.0 MB ~ February 9th 2021 Changelog: Updated MPC-HC to version 1.9.9.0 Updated MPC Video Renderer to version 0.5.3.1640
April 13, 20213 yr Author Version 16.1.2 Mega ~ 58.3 MB ~ April 12th 2021 Changelog: Updated MPC-HC to version 1.9.10.86 Updated LAV Filters to version 0.75-2-gddef5 Updated MPC Video Renderer to version 0.5.3.1699 Updated Icaros to version 3.2.0 Updated Codec Tweak Tool to version 6.5.1
May 22, 20213 yr Author Changelog 16.1.2 to 16.2.0 ~ 2021-05-20 Updated MPC-HC to version 1.9.11.49 Updated MPC Video Renderer to version 0.5.3.1708 Updated Codec Tweak Tool to version 6.5.2 Updated Icaros to version 3.2.1
June 11, 20213 yr Author Version 16.2.5 Mega ~ 60.5 MB ~ June 10th 2021 Changelog: Updated MPC-HC to version 1.9.13.14
July 21, 20213 yr Author Version 16.3.5 Mega ~ 58.7 MB ~ July 20th 2021 Changelog: Updated MPC-HC to version 1.9.14.18 Updated MPC Video Renderer to version 0.5.5.1733
September 3, 20213 yr Author Version 16.4.0 Mega ~ 58.2 MB ~ September 3rd 2021 Changelog: Updated MPC-HC to version 1.9.15.54 Updated MPC Video Renderer to version 0.5.5.1748 The option to add MediaInfo shortcut in explorer context menu is now disabled by default. You can of course still enable it in the installer. MediaInfo can also still be accessed through the "Send To" submenu in Explorer. The option for MPC-HC to remember playback position for videos is now enabled by default.
September 15, 20213 yr Author Changelog 16.4.0 to 16.4.5 ~ 2021-09-14 Updated MPC-HC to version 1.9.15.76 Updated LAV Filters to version 0.75.1-3-gc0c87 Updated MPC Video Renderer to version 0.5.5.1759
September 18, 20213 yr Author Version 16.4.6 Mega ~ 58.8 MB ~ September 17th 2021 Changelog: Updated MPC-HC to version 1.9.15.79 Updated LAV Filters to version 0.75.1-4-gfaff6 Updated MPC Video Renderer to version 0.5.5.1761 Updated MediaInfo Lite to version 21.09
October 21, 20213 yr Author Version 16.5.0 Mega ~ 58.8 MB ~ October 20th 2021 Changelog: Updated MPC-HC to version 1.9.16.46 Updated LAV Filters to version 0.75.1-9-gde277 Updated MPC Video Renderer to version 0.5.5.1767
November 5, 20213 yr Author Version 16.5.2 Mega ~ 58.8 MB ~ November 4th 2021 Changelog: Updated MPC-HC to version 1.9.16.63 Updated MPC Video Renderer to version 0.5.5.1781
December 3, 20213 yr Author Version 16.6.0 Mega ~ 58.8 MB ~ December 2nd 2021 Changelog: Updated MPC-HC to version 1.9.17.21 Updated LAV Filters to version 0.75.1-12-g75776 Updated MPC Video Renderer to version 0.5.5.1801 Updated Codec Tweak Tool to version 6.5.5
December 14, 20213 yr Author Version 16.6.5 Mega ~ 59.1 MB ~ December 14th 2021 Changelog: Updated MPC-HC to version 1.9.18.0 Updated LAV Filters to version 0.75.1-19-g80347 Updated MPC Video Renderer to version 0.5.5.1802 Updated GraphStudioNext to version 0.7.1.69
January 4, 20223 yr Author Version 16.7.0 Mega ~ 59.1 MB ~ January 3rd 2022 Changelog: Updated MPC-HC to version 1.9.18.35 Updated LAV Filters to version 0.75.1-28-g56705 Updated MPC Video Renderer to version 0.5.7.1811
January 31, 20223 yr Author Version 16.8.0 Mega ~ 59.6 MB ~ January 30th 2022 Changelog: Updated MPC-HC to version 1.9.19.0 Updated LAV Filters to version 0.76-2-g642bf Updated MPC Video Renderer to version 0.5.7.1812 Updated GraphStudioNext to version 0.7.3.1 Updated Codec Tweak Tool to version 6.6.0
February 26, 20223 yr Author version 16.8.4 ~ 19.3 MB ~ February 25th 2022 Update for: K-Lite Codec Pack 16.8.0 and newer (Basic/Standard/Full/Mega) Changelog: Updated MPC-HC to version 1.9.19.34 Updated LAV Filters to version 0.76-9-g5da67
March 21, 20223 yr Author Version 16.9.0 Mega ~ 59.7 MB ~ March 16th 2022 Changelog: Updated MPC-HC to version 1.9.20.0 Updated MPC Video Renderer to version 0.5.7.1829
May 13, 20222 yr Author Version 17.0.0 Mega ~ 58.5 MB ~ May 12th 2022 Changelog: Updated MPC-HC to version 1.9.21.24 Updated LAV Filters to version 0.76.1-3-ga6b20 Updated MPC Video Renderer to version 0.5.7.1858 Updated Codec Tweak Tool to version 6.6.5 Removed AC3Filter. This filter is old/obsolete/redundant and wasn't used by default. Only a tiny amount of people used it. Removed options to use ffdshow for decoding. These decoders are also old/obsolete/redundant and weren't used by default. There is no good reason for people to use them either. If you are stubborn, you can still enable them manually with Codec Tweak Tool after installation. The ffdshow processing filters are still available for those who need additional processing abilities. Added new options to load them in all compatible DirectShow players.
June 15, 20222 yr Author Version 17.0.5 Mega ~ 57.7 MB ~ June 14th 2022 Changelog: Updated MPC-HC to version 1.9.21.40 Updated Codec Tweak Tool to version 6.6.7 Updated Icaros to version 3.3.0 b2
November 13, 20222 yr Author Version 17.3.0 Mega ~ 59.0 MB ~ November 12th 2022 Changelog: Updated MPC-HC to version 1.9.24.0 Updated LAV Filters to version 0.77-1-gfd3c1 Updated MPC Video Renderer to version 0.6.4.1963 Updated Icaros to version 3.3.0 rc1
January 12, 20232 yr Author Version 17.4.0 Mega ~ 59.1 MB ~ January 11th 2023 Changelog: Updated MPC-HC to version 2.0.0.0 Updated LAV Filters to version 0.77.1-2-g8637e Updated MediaInfo Lite to version 22.12 Updated Icaros to version 3.3.0
